28 spline axle hp limit
Old 12-06-2015, 10:09 PM
VandykeT/A's Avatar
Default 28 spline axle hp limit
I'm going to do a 8.8 swap in my camaro (450rwhp m6) and I'm curious what the stock axle can handle and what a 28 spline moser axle could handle hp wise. I know the rangers come with 410 posi 28 splines and stock axles will fit the ford carrier. Basically what I'm asking is finding a 31 spline carrier necessary for a dd that gets to see the track maybe twice a year. The car will be on slicks at the track. Would a moser 28 handle that?
Old 12-08-2015, 12:34 AM
SteenH's Avatar
Short answer I'd assume no. the clutch car isn't helping your case either. Realistically you're going to have to watch how you launch on the 31s with the 6 speed even
Old 12-08-2015, 10:35 AM
weedburner's Avatar
Stock Ford 28 spl 1040 8.8 axle has a yield of around 2835 ft/lbs each.
Moser 28 spl 1541 8.8 axle has a yield of around 4424 ft/lbs each.
Stock Ford 31 spl 1040 8.8 axle has a yield of around 3725 ft/lbs each.
The Ram PowerGrip will somewhat protect your drivetrain. If it were a PowerGrip HD (metallic), that clutch would pass along a lot more shock from dumping the clutch, more likely to break parts.
You should be fine on Moser 28's with your current clutch and power level.
Quick Reply: 28 spline axle hp limit
