need help with 3ch and 4 ch
Old 01-27-2016, 01:20 PM
SStressin's Avatar
Default need help with 3ch and 4 ch
so my car is originally a 4 channel car with tcs and abs. when i bought my 9 inch i still had tcs. so i have 4 channel rings put on the axles. since then i have taken out cruise control and the big tcs box in the front driver side bumper so i always have tcs off. but i still have abs. my question is do i keep the 4 channel rings or do i need to change to 3 channel. i dont want any abs light on.
Old 01-27-2016, 02:25 PM
FirstYrLS1Z's Avatar
How do you know you still have ABS ?
It is my understanding that on a 4 channel system(ABS & TC),The ABS & TC work off the same components and that disabling one disables the other. The 3 channel hydraulics and electronics are totally different from the 4 channel hydraulics and electronics.
Old 01-28-2016, 02:51 PM
SStressin's Avatar
i am unaware if i still have abs. i thought id have to remove the abs to loose it. if that is the case that once i remove the tcs then i loose abs to then i might as well delete the abs block. this is the reason for my post is to ask questions about what i have. and if i need to switch my 4 channel reluctor rings when i put my 9 inch back together. does anybody have any more insight on this?
Old 01-31-2016, 06:15 AM
SStressin's Avatar
Bump... Can anyone help out with this situation
Old 01-31-2016, 07:34 AM
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
It is not easy to convert a 4 channel car to a 3 channel, as the electronics (EBCM) are different. The easiest thing to do is to remove the ABS bulb. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old 01-31-2016, 11:21 AM
SStressin's Avatar
So i keep my 4 channel reluctor rings as is. Do i have abs currently that i took out traction control? If i lost abs doing that i might as well do the abs delete kit. Just want to make sure i dont have to change my reluctor rings before i get my center section back
Old 01-31-2016, 12:06 PM
LS1Tech Sponsor
You can keep the rings on there, they won't hurt anything. You won't have ABS without the traction control being hooked up, you're back to old school brakes. Bob
__________________
Quick Reply: need help with 3ch and 4 ch
