How to swap clutch LSD for Torsen???
LS1Tech Administrator
Received 1,795 Likes
That's unfortunate, considering that the original factory recommendation was actually for conventional. But this LSD has been out of production for 18 years now, so I guess they don't bother to service them at this dealer with the proper gear oil any longer. That's bad news for their customers.
For best operation and longest service life, I'd stick to the original recommendation.
GM does still offer the proper gear lube, part #89021669 (80w90 conventional). Original part was #12345977 but the new number is the same lube.
Looks like the part number for the LSD additive has changed, was previously #1052358 but now seems to be listed under #88900330 as mentioned by FirstYrLS1Z above.
Been doing some reading.
What do you guys think about running standard gear oil with no modifier. I know it'll be noisy, but it will also work better. Seems modifier is there to make the LSD quiet and not using modifier will not hurt it.
Thoughts?
Thoughts?
With an Auburn, I would not skip the additive, nor do I see how it could work any better without it. Mine has always worked perfectly with the additive, I can't see any advantage to not using it.
I've been searching the web for way too long now on whether to use friction modifier of not and what I have concluded is there is a lot of crap information out there's.
From what I gather, the best is to use 80w90 non synthetic.
And I'm not going to use the friction modifier. Some say it will wear the auburn quicker, some say it won't. But it definitely will make it have more lock up, which is what I want. I know it will be noisy.
Since eventually I'm going to put a better LSD in there anyway, I really don't care about longevity, so I figure I have nothing to loose.
I'll do this tomorrow and see what happens. I have another track day in 3 weeks, do I'll see how it performs.
Good luck to you.
He's looking to launch harder off of the apexes/corner exits, as this car is used on a ROAD COURSE, not the street/strip ONLY, like most on here.
Now, whether or not the lack of the FM additive will help promote that type of off corner lockup or not with the Auburn's cone clutch set up, who knows??
Exactly. So I've got a bottle of FM in the garage. In 2 weeks I have another track day, I'll be able to see how it performs. I'll also get a couple of weeks of street miles. If it doesn't do well, I can add the FM. If I blow it up, I'll put the torsen style out of my 99 parts car, although I don't think that'll happen.
The additive is a 'friction modifier'. The EP additive in gear oil prevent the clutch from grabbing/locking. That's where the 'noise' comes from,the cone clutches lock and then unlock because of the 'straight' lube,the modifier allows them to stay locked up to their designed torque setting as designed.
#32
I mean no disrespect but I think that's barckwards.
#34
#35
Update: I filled the diff with Lucas regular 80w90. I did mostly highway driving with a couple of parking lot maneuvers. I notice a little noise in tight turns but nothing bad. On the way home I made a hard right turn from a stop and got on the gas hard. The LSD locked up hard and sideways I went. The same LSD with the expensive grape flavored synthetic gear oil, I would have lit up the right tire.
I'll drive it more tomorrow, but so far the diff actually seems pretty happy with no friction modifier. Much happier than the synthetic stuff.
#36
You might find that it will work even better, or at least work as well but be quieter, with the additive in addition to the proper conventional 80w90 that's now in place.
#38
Yeah I agree that I'm not fully testing the theory with no addative, but I'm not going to waste the money to keep draining and filling the diff. It seems to be working really well, so I'm going to leave it alone. I'm going to drive around town more today so I'll get a better idea of how it's working.
I've got another track day coming up. I know the LSD with the synthetic stuff wasn't working well at all. This track has a lot of right hand turns and I kept lighting up the right tire on exit. Going back to the same track will be a good test.
Thanks for everyone's help and opinions.
