Rearend Oil?
Rearend Oil?
My Moser has been leaking. I want to add oil to the differential.
What oil do I use to top it off?
Is it better to change the oil instead?
How do you know how much oil to put in it?
Thanks,
James
Thanks,
James
There is a plug on the side,where you add the fluid. Take it off and use your finger to check if it is low. My old car had a slow leak but it didnt loose enough to need a top off. My Strange came filled with Pennzoil SAE 80W-90 GL-5. It wont take very much,I bet less tan one or two squirts.
