This is what having a spool in a daily driver does!
Originally Posted by BigPlanTransAm
what are the skinny marks from? are you plowing your front tires?
I have NO problems with the spool. I actually prefer it to a posi
The only things I watch out for is parking. Dont leave the spool loaded up when you park. Move forward/backward to release the pressure on the axles and then go into your spot.
Im still deciding myself spool, posi, or locker. The spool doesnt seem that bad at all. I have heard that it cuts you DR life down alot. Does anyone know how much?
Originally Posted by TheBlurLS1
my rear end is stock and it NEVER EVER only spins one tire. when it was on the lift, i couldnt spin the tires independantly of one another if i tried. is this normal?
Originally Posted by BTL FED
It does make a pretty big difference because whenever you turn you are dragging a tire across the concrete
Well I went ahead and got the 9" spool. We will see how it works out.
