Anyone running flat top/4.8 pistons in a 5.3?
Just look at the numbers. By going to a flat top from an 8cc dish, compression goes from 9.5:1 to 10.47:1
If you have the right fuel for the compression, it works out great!
Is there any tangible benefit to increasing compression?? Dumb question, but you be the judge....
One has 706/862 heads with a used LS2 cam with a TBSS 2500 Stall, The Other has 243's with a used TSP Stage 2 Truck Low lift cam with a Circle-D 3200 Stall. Both used LS6/LS3 Springs.
The New one is fully custom with a Tony MAMO Top End and valvetrain package but its never been run.
The following users liked this post:
G Atsma (Today)
If you believe the 4% per point of compression increase, you would be looking at about 10rwhp on a stock 5.3. Whether that is worth it depends on how much extra work or dollars it will take for you to do it. However, that extra power comes directly from using the fuel more efficiently, which means better fuel economy. Unfortunately, if the added compression makes your engine require premium instead of regular gas, the increased economy would be offset by the higher fuel cost. Even the simplest questions become complicated when you look at them too long.
