help with setting up my rearend angles ..ASAP
ok my cars getting a built 10 bolt today and i am wanting to setup my rear for the best traction for daily driver use.... basically what angle should i set my tq arm to ? also on my lca relocation brackets there are 3 holes which ones should i use ?
thanks
thanks
The lower your lca's are the better traction from what i know. i run -2 on my torque for street and strip.....
thanks
thanks
Moderator
Go with the lowest hole, and only go up if you encounter
wheel hop on braking. Otherwise it's all bonus. I see -1 to -2
recommended for pinion angle; more negative = more bite,
but more absolute angle error makes for more driveshaft
vibration and scrub which will make for pinion seal leaks
and general annoyance.
