Moser 9" and removing axles! LS1 to LT1 swap...
Ok the backing plates are loosened and what not...how do i get the axles out? I am swapping out the rear(currently in an LS1 to an LT1) anything else I should know?
same four bolt pattern on the flange but the caliper mounts are different. Also when you use one of the moser bolt-in rears on an LT1 car they have you put some spacers in to space out the axles like 1/8" If you are going to swap caliper mounts/backing plates you will have to take off the bearings so I would get the spacers also from moser.
Unless you are going to use the LS1 brakes on the rear
