is my rear end broken?
Old 02-04-2005, 08:32 AM
CRM
CRM's Avatar
Question is my rear end broken?
hey just a question ?
w hen i am stuck on ice pulling out of a parking spot opnly one wheel burns out?
but when doing a burnout they're both fine
plus at time when peeling from a spot it seems like wining noise coming out (not sure if its from the tire?)
so... anyone knows anything about that >????plese say so...
stock rear end and stock gears!
Old 02-04-2005, 10:17 AM
CRM
CRM's Avatar
no one?
Old 02-04-2005, 10:36 AM
Muffracing's Avatar
How bad is the whine. Any clunking? Pull the cover and check the teeth on the ring and pinion gears.
Old 02-04-2005, 10:54 AM
CRM
CRM's Avatar
basicly there's whyning at like 2000 rpm while passeget wheel is spinning as i give more rpm wheel starts spinning , same goes when this happens on the other side,
but someone told me that i have somekinda limited slip rear since i dont have tractio but from what ui think all f body stock rears are the same.?
cant figure it out!
Old 02-04-2005, 11:49 AM
Race your car!
JL ws-6's Avatar
Could be a blown posi unit. If that ends up being the case, don't buy a new one for the 10 bolt, just do yourself right and buy a 12 bolt setup.
