Differential Transfer
I recently removed the posi out of a 96 Trans Am A4 with 3.23s. I was wondering if i could just remove my own and directly install it because all i did was unbolt the screw holding the rod. Removed the rod and pushed the axles in then removed the c-clips. So if i did the same process to my own rear then reverse it to install the other would it work??
