How hard is it to change the pinion and carrier bearings?
First of all, I did a search, but most of what I found dealt with gear swaps or pinion seal replacements. I'm looking at the bearings in the rear end also, as stated. I'm concerned about screwing up the backlash and any other settings in my rear end. I've done the wheel (axle) bearings before, no problem. The only thing with those is that I didn't have to really take apart the rear end. I have a decent set of tools; nothing too extreme, but usually enough to get by. Am I going to be ok with this, or should I take it to a shop? How much should I expect to be charged? Thanks.
-Marc
-Marc
You can do it. This link will let you know what you are getting into.
http://www.fullsizechevy.com/fscu/axletech/
