Do I have the wrong gears?
I bought a new set of Zoom gears on ebay that was advertised for a GM LS1 10 bolt rear end. When I got them it said on the box:
Zoom 4.11
GM 10 bolt rear end 8.2
37 tooth ring gear
9 tooth pinion gear
I know that the 8.2 and the 7.5/7.65 rear ends are different but I thought maybe they were in a different box. When I measure the ring gear with the teeth out it comes to 8 1/8" which is very close to 8.2. But when I measure them on the back side that bolts to the differential they measure 7.5". Which is the correct measurement to go by?
Zoom 4.11
37 tooth ring gear
9 tooth pinion gear
LS1TECH Sponsor
You bought the wrong gears.... One of the problem with internet only sales.....
If you'd like a correct set of gears, we have them from a number of companies....
__________________
