8 3/4 rearend
Old 02-18-2006, 01:10 PM
patriotformula's Avatar
Default 8 3/4 rearend
Anyone ever put one of these in an Fbody. My dad is a huge mopar guy and wants to fab up an 8 3/4 in my formula. Should be lighter then a 9 inch and stronger then a 12 inch and fairly cheap. Also has anyone ever run 4:56 gears in a 6 speed car. How'd that work? Thanks for the info.
Old 02-18-2006, 04:00 PM
LS1Tech Sponsor
Scott@DrivelineSolutions's Avatar
I know where there is one for sale here in MI. PM me for more details.
Old 02-18-2006, 07:53 PM
Flossin' twin turbos
Moparnos (The SLP Guy)'s Avatar
there very good rears just as strong as a nine but lighter than one too. give it a shot you can't go wrong
Old 02-18-2006, 10:17 PM
Hot Wire's Avatar
I have one for sale on the Motown board that I used in my car it is a very nice set up. I don't have any pics right now the car is out a chassis shop getting a new cage etc. I ran a stock chrysler posi with a richmond 4.30 gear car has been 10.86 on spray and street driven. I have no need for this rear end anymore I have ordered a fab 9 since the new motor will be putting out over 1000hp and I don't want to hurt a good 8 3/4 rearend.
Here is one pic I have taken while I was removing the roll bar rear floor of car before sending out for the new cage to be installed (Pardon the dust)
Old 02-19-2006, 09:50 PM
What are you looking to get out of it? Could you send me an email to dcook@iastate.edu. Thanks alot.
Old 02-19-2006, 10:22 PM
Hot Wire's Avatar
Will do I want $900obo total. I want $500 for the axles and housing and $400 for the center section. Or best offer, I have a suspention parts for sale also.
Old 02-20-2006, 12:31 PM
slow trap's Avatar
i can't remember the casting numbers but i think some 8 3/4" aren't as good as others.
Old 02-20-2006, 06:56 PM
LS1Tech Sponsor
Casting numbers 489 and 742 are the two you want, they use larger pinion bearings. The 741 and X castings use very small pinion bearings about the same size of 10 bolts.
Old 02-21-2006, 07:32 AM
slow trap's Avatar
thanks scott,i couldn't remember the numbers,now i don't look like a fool.
Quick Reply: 8 3/4 rearend
