rear end
Old 03-10-2006, 01:39 PM
2000ss06's Avatar
Default rear end
How Do I change and check my rear end fluid. What do I use to get that filler plug out?
Old 03-10-2006, 01:49 PM
Dans2000SS's Avatar
Use a 3/8 ratchet and extention to remove the plug. The fluid should be up to the bottom of the plug hole. To change the fluid, just remove the rear cover bolts and pry the cover loose from the bottom and let it drain out. Buy a new gasket and 2 qts of gear lube, and refill until it starts to come out of the plug hole.
Hope this helps.
Old 03-10-2006, 03:45 PM
2001NBMZ28's Avatar
On a complete drain and refill don't forget 4 oz of limited-slip differential lubricant additive.
Old 03-10-2006, 06:48 PM
thunderdan74's Avatar
Do you need the additive if you're using Royal Purpul Max Gear?
Old 03-11-2006, 01:06 AM
LS1powerhouse02's Avatar
i didn't think you needed to put an additive in it. I never have. And i am running castrol i believe synthetic rear end fluid.
Old 03-11-2006, 07:39 AM
'Bird Director
y2k_ta's Avatar
Location: Central Indiana Honors: 4th grade spelling bee contestant
Read the side of the bottle. It should tell you somewhere whether or not the additive is included.
Old 03-11-2006, 10:00 AM
Default I'm thread-jacking, nobody moves and nobody gets hurt!
How many bottles of the purple stuff do I need? They only had 3 at the store so, I cleared them out hoping it was enough
Old 03-11-2006, 01:20 PM
ttt, anbody know how much fluid is needed in the rearend?
Old 03-11-2006, 01:41 PM
2001NBMZ28's Avatar
My owners manual says 1.75 quarts...
Old 03-11-2006, 07:12 PM
Dans2000SS's Avatar
Two bottles will do it and Royal purple has the additive already in it.
Old 03-12-2006, 10:22 AM
keliente's Avatar
You probably have a torsen.
If you have an auburn you'll need the fluid or it may make noise.
