GEAR SELECTION PLEASE HELP ME
Old 04-08-2002, 03:04 PM
68LS1eqpt's Avatar
Default GEAR SELECTION PLEASE HELP ME
Just picked up the 9inch and im wondering if i should go with a 4.10 or a 4.30
Ive got stock heads/cam
ls1edit
th400 with stock gears
and both 26inch and 28inch tires
one for motor one for spray
let me know if the 4.30 will be too much
thanks
Old 04-08-2002, 04:43 PM
MIGHTYMOUSE's Avatar
Default Re: GEAR SELECTION PLEASE HELP ME
i'd think thats good till around 125 trap speed with stock rev-limit and 26" tires.. im sure someone will fine tune that figure.
Old 04-08-2002, 08:33 PM
Ragtop 99's Avatar
I estimate about 115 mph assuming 4.30s, 6200 rpm rev limiter, 3% converter slip, 28" tires with no growth on the big end. With a lock up switch, figure about 120 mph.
Old 04-08-2002, 11:50 PM
68LS1eqpt's Avatar
should i go with the 4.30 or no, ive got a decent size converter with no lock up
Old 04-09-2002, 08:09 AM
Ragtop 99's Avatar
If you're are going to spray a big shot, 150 or more and want to stay within the stock rev limiter, I would do 4.10s. ET wise, 4.30s vs 4.10s won't give you much, and 4.10s will give you more flexibility in the mph catagory.
If you are willing to swap out your springs and pushrods and spin to 6600, then 4.30s would be ok.
Old 04-09-2002, 11:01 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,102 Likes on 723 Posts
I have a similar problem.
I am running 26's and 4.10's, and have been going thru the traps around 6400 (unlocked).
For spray, I need true 28's but I think I am limited to about 140mph at 7000 rpms.
If you plan to spray big, say 150 plus, I would not go nuts with gear.
Old 04-09-2002, 05:00 PM
68LS1eqpt's Avatar
ive got a 60ft monster and im not that good on the big end. I will spray a lot and shift around 63-64 with stock springs. When i spray ill be on a 28inch tire. I think ill go with the 4.30
