how do you get the u-joint out - help
Old 04-12-2006, 08:39 PM
circusboy's Avatar
Default how do you get the u-joint out - help
i have a three rivers 12564004 aluminum drive shaft. how do you remove the rear u-joint?
Old 04-12-2006, 10:17 PM
Wyoming T/A's Avatar
snap on makes a little press to remove without shaft damage
Old 04-12-2006, 11:01 PM
circusboy's Avatar
thanks
Old 04-12-2006, 11:02 PM
LS1Tech Sponsor
Scott@DrivelineSolutions's Avatar
Use a hand held propane or map gas torch, a bernzomatic works best, and heat the ends where you see the nylon that has been injected from the OEM.
The nylon will start to ooze out and will stop, both side will need to do this, and use a dead blow hamer that is made of rubber to smack the driveshaft end yokes while the other side of the u-joint is clamped in either a bench vise or press.
Old 04-13-2006, 06:39 AM
circusboy's Avatar
thanks alot for the info
