new Strange rear leaking at e-brake..
Old 04-29-2006, 01:41 AM
0rion's Avatar
Default new Strange rear leaking at e-brake..
Just got the break in miles on my rear tonight and noticed a little residue on my drivers side rim. After crawling under the car it's coming from the bracket that holds the e-brake mechanism. Anyone ever run into this problem and have a fix for it? Can I take that bracket out and permatex it?
Old 04-29-2006, 09:30 AM
sykotic's Avatar
Sounds like an axle seal.
Old 04-29-2006, 10:37 AM
peterock98's Avatar
Yeap it's axle seal.My strange 12 bolt gave problems since day one.Mine leaked from the drivers side axle and from the pinion. It's been rebuilt 2 times.The first time strange rebuilt it under warrenty.The second time I had to pay for it now I have a $4,300 12 bolt rear.Now it's good,but I had to pay for a new posi,ring and pinion all new bearings and seals.The only parts I could reuse was the axles. I suggest you send it back and get the dana S 60.
Old 04-29-2006, 10:58 AM
0rion's Avatar
Not what I wanted to hear guys. Please tell me this rear isn't going to have to come back out? This sucks. It's friggin brand new and I basically just got it in. What a summer.
Old 04-30-2006, 01:49 AM
0rion's Avatar
I was thinking tonight that if the axle seal was out wouldn't it leak at the backing plate? It's definitely leaking at that rubber boot that goes around the e-brake mechanism. There's no oil above that point. I've never looked inside a rear so I'm pretty clueless about it at the moment. I just assumed the axle seal would be on the end of the axle and make it leak where the backing plate bolts up.
nevermind,
I went out and looked at my old 10 bolt and see what you're talking about now. I guess strange quality isn't what I thought it was.
Old 04-30-2006, 09:57 AM
peterock98's Avatar
Call strange Monday give them your zip code and let them find you a repair shop . How old is the rear?
Old 04-30-2006, 11:23 AM
0rion's Avatar
I'll call them monday. Thanks for your help. The rear has 250 miles on it so I was a little pissed to say the least. Just do a search on my nick and look at the fuel pump problems and **** I've had this year. Hasn't been a good year for mods and I'm sick of working on the car. Thanks again for your help.
