Clunking only while turning
like the title says, i get clunking only while turning at low speeds. I read that this is fixed by changing the gear oil and adding in the Posi additive from a dealership. Is this correct? Could this also be a sign of the diff going out or is it more than likely just the lack of the additive in the gear oil?
I have had this issue with multiple camaros. There is a vent for the axle that gets plugged. Its above the fill hole to the left a little (if looking at the fill hole) on the top. There is a little plastic chimney/vent that gets pluged or falls off and the hole gets plugged. I would check this first.
I would also change the fluid soon after this too.
