9" off center?!
9" off center?!
alright i just found out that my rear is not center. it is about 1.5-2" to the right. i have the stock springs in, did i install it wrong? or do i need to get a adj. panhard bar? could my adj spohn TQ cause this?
Mine was off by maybe a half inch. That's a lot. I assume you've lowered the car and measured after everything settled into place. The torque arm shouldn't cause that. Double check everything. Compare measurements from the center of the yoke to the panhard attach point on the old and new rears. The next thing would be the adjustable panhard.
Where are you measuring from? Bob
