12 bolt cover??
12 bolt cover??
Are the extra bolts on the cover for adjustments? I have 4.10 with a aluminum cover/spool and about to put in new wheel studs. Just wanted to know if there is anything special about removing and installing the cover? Thanks
reply
Just back them off of the bearing to remove the preload. When you button the rear end back up and get all of cover bolts tight snug those back down faily tight and it's ready. You might want to put some silicone on those bolts also. I have had some that let alittle gear oil leak past. Just enough to keep the cover wet.
