Rear end
I believe they recomend doing it every 60 K, and its not that hard to do, just unbolt it and let the fluid drain, not a bad idea to slip a new gasket in their if you want, then bolt it back up and add the new oil. but if its a limited slip rear your goin to need to get the GM additive to add to the oil as well
