Anyone make a good gasket for a 9 inch???
I put a THICK bead of RTV high temp all around then bolted the center on and there was alot that squeezed out that made a bead around the lip of the case and I have had NO leaks whatsoever.
I dont think I have used a 9" gasket in....... I dunno...... 10+ years.
Clean the surface's with brake cleaner, let it flash and drop a bead around the center section and drop it into the housing. You may not want to do it, but.... it is still the best way to seal it.
