whats needed for 12 bolt installation....
Old 07-19-2006, 06:05 PM
presto_z's Avatar
Default whats needed for 12 bolt installation....
ok...10 bolt is coming out and moser 12 bolt is going in soon.....what do i need to get besides the axel itself????
Old 07-19-2006, 08:36 PM
keliente's Avatar
Exhaust clamps for the rear swaybar. Fluid. Zipties to secure brake lines/etc.
https://ls1tech.com/forums/gears-axles/514327-how-install-12-bolt.html
Old 07-20-2006, 02:27 PM
presto_z's Avatar
thanks...i wasnt sure if there was anything major... i didnt wanna have any supprises....i heard that i need new u-joints... is this true???
Old 07-20-2006, 02:36 PM
keliente's Avatar
Yeah but that is going to depend on what yoke you went with (1310 or 1350).
Old 07-20-2006, 07:45 PM
GIJosh's Avatar
I went with the better yoke and needed a new u joint. Go to Napa and ask for number 447. Visually it doesnt look much different from stock, but trust me, you`ll need to swap it out.
You`ll also have to have the axle bearings pressed on after the backing plates. The instructions werent very clear on this part.
I guess you can use exhuast clamps for the rear sway bar, but I just ordered the mounting kit from Spohn and it worked out real nice. Depends on your budget I guess.
And, you`ll also probably want to paint it. It doesnt come painted. A friend put POR15 on his, but I clear coated mine and it looks killer, I dont know how long the clear coats going to work though.
Oh and make sure Moser sends you the nuts for the backing plate bolts. They cheaped out on me on this part and I had to wait till morning for the hardware store to open.
