Rear won't sit still... PLEASE HELP!!
When I try to do a burnout with my linelock on the rear end instantly kicks to the right really hard. I had a moser 12bolt installed with 33 spline axels and a detroit tru trac. Before the 12 bolt I could do burnouts all day and the car would stay straight. Now as soon as the tires break loose it goes right and I'm talking drastic! Any input you could give me would be much apreciated.
As far as rear suspension goes I have:
BMR Non Adj. LCA's
SLP Adj. Torque arm
UMI Relocation Brackets
QA1 Adj. Shocks
BMR Adj. panhard bar
BMR Sway bar
By the way, it did this before and after I put the QA1 shocks on.
BMR Non Adj. LCA's
SLP Adj. Torque arm
QA1 Adj. Shocks
BMR Sway bar
Are you sure before you installed the new rear, that both tires were seeing equal traction or wheelspin? If you have the BMR Xtreme rear anti roll bar, you can pre load it which should help with your problem. Bob
Mine does that too... only at certain spots in the road though. If the road is pitched or there is a big crown int he middle, she will kick me almost 90* from when I started...and fast too.
But on a level piece of road and as long as im centered over the crown, it sits perfectly still all day if I want.
Justin
Justin
