will an A4 carrier from 02 z28 workon my 00 M6 T/A
Location: Your girl's back door giving her the long stroke while you're at work
If you are swapping the entire carrier(gears and all) then it will work. But if you are swapping the carrier only and reusing your stock gears then you'll need to run a ring gear spacer. you can get it from Speed Inc
