ABS and the 9"
ABS and the 9"
I got a new rear with 3.89's installed and it does not have the parts for the ABS. Is there a way to install the harness without getting a new rear? I got my rear in a deal for a blower i traded. Long story just curious to see if it can be updated.
Damon
Damon
It can be done with some fabrication,you mount a sprocket on the yolk and fab a bracket to mount the sensor to within .050 or so. Gear ratio used will determine the #
of teeth on the sprocket as it runs off the pinion now and not off the ring gear.
