GU6 and steel Drive shaft
Old 06-24-2007, 01:34 AM
tyson__91's Avatar
Default GU6 and steel Drive shaft
Alright ive seen it like 6 times on search if you have a steel drivshaft you have 2.73's. Well on my 99 Z28 M6 i have a steel DS but GU6 rpo code on door. So did some M6's with 3.42's have steel DS or whats the deal. Thanks Guys.
Old 06-24-2007, 07:55 AM
gillbot's Avatar
no, you should NOT have a steel driveshaft. did you buy the car used? if so someone may have sold the alum one for a few $ before they got rid of the car. You need to check your gears for sure and probably pick up an alum shaft.
Old 06-24-2007, 12:50 PM
keliente's Avatar
I had an M6 with a steel driveshaft (2001). I highly doubt it had been changed as the other owner was an old guy and just hauled his dogs around in it.
Old 06-24-2007, 02:38 PM
LS1W66's Avatar
Probably didn't have an Aluminum shaft available when the car came down the assembly line so they use what they had. I've seen stuff like this before.
