10 bolt howl
10 bolt howl
Hello my car's got about 76k on it and the rear end kinda howls. I'm thinking axle bearing since it pretty much goes away if I pull up on the e-brake somewhat engaging the brakes. The noise is on the right side.
Seems to get louder the faster I go but it's very consistent.
Axle bearing?
Axle bearing?
Well the axle bearing is the easiest to start with. It most likely is and I had a howl from my right side which turned out to be the axle itself. The only way to check is to pull the axle and see what you have going on.
