Gear swap
Gear swap
Well since my 4.10's are about to come apart, and I dont have money for a 9 inch yet I am planning to put the 3.42's back in for the time being. I bought a cheap install kit from summit with just the shims, pinion seal, and crush sleeve. Im not worried about the bearings and stuff. I have a solid pinion spacer in now and was wondering if I should reuse that or use the new crush sleeve? Also can I use the same pinion shims for me pinion depth or do I need to reset it?
