S60 Torque arm
S60 Torque arm
Had a BMR non adj on, and it rubbed the floorboard. The previous owner removed it and put the stocker back on and sold the BMR. Does anyone make a better fitting TA for the S60. I dont mind beating on the floorboard some, but im not going to notch a whole in it. Anyone with an S60 what TA are you using? Also want a loop too. Thanks.
I had to do some sheetmetal movement to get my t.a. in for my 9". I think its the same for all of the rearends. I have a Granatelli Drive shaft loop and have plenty of room for everything. Its a real nice heavy duty unit. Highly recomend one.
LS1Tech Premium Sponsor
i have a complete setup with adjustable pivot link tunnel mount crossmember. it includes a driveshaft loop and i have personally installed one in a car w/ a S60. there are no clearance issues at all with these. it is a direct bolt-in assy. torque arm is made of chromemoly tube and is adjustable.
