Something is wrong, can't figure it out..
I've always had some rear end noise - as I think we all do. I did some spirited driving and now I have a noise that is a clicking noise and it gets better or worse based on how fast the car is moving - click gets faster with higher speed, etc. Someone said to just replaced the rear end since you can find them for like 250. I was thinking that maybe it could be a bearing, etc, but I just don't know. I looked for play in the wheel but couldn't find any. I have auburn 4.10's and a summit girdle. The rear end still seems to function fine which is why I hate to swap it with another. Do rear wheel bearings go bad often on our cars? How do you know if it is a bearing...?
This must be happening to alot of these cars around 100k. I replaced U-joints, axles, axle bearings, seals, brake pad, and fluid trying to figure the clicking out. None have solved the problem. Mine gets louder when I cut left hard and louder after I have been driving hard.
It makes the noise once for every wheel revolution, so can't be the drive shaft or pinion gear/bearings. I'm thinking the stock Torsen LSD is pretty worn and scrapping itself somehow or a worn ring gear. Anyway, I gave up on this one for the winter...can't hear it now with the windows up and it drives fine with a 2-wheel peal.
If it turns out to not be the U Joint, I've located a 3.42 10bolt 4 channel with 8k original miles on it for 400 bucks. Hopefully the U Joint is the problem. It's a bad time of year to be having car issues. You know what I mean.
Thanks guys.
