Midwest Chassis & Performance fab rearends... new pics
#3341
To show some appreciation we are going to run a 10% sale on our standard lower control arms and weld on relocation brackets.
Purchase Standard Lower Control Arm
Purchase Weld On Relocation Brackets
#3347
C0046 ………….. Left Rear Wheel Speed Circuit Range/Performance
With this the common issue is the sensor itself isn't sitting into the hole properly. You need to shave one side to make sure it isn't at an angle. Another issue is the reluctor wheel may of been bumped after assembly and not spinning 100% true. Easy fix with a screw driver, go around it and make sure it is spinning true.
C0051 …………. Right Rear Wheel Speed Circuit Range/Performance
Same as the above.
C0245 ……………………… Wheel Speed Sensor Frequency Error
This may happen when unplugging the harness and the wires with age become brittle and you may have harmed the harness. With that said it could lead to the other codes. However I have never seen this code come up but have seen the sensor codes if the sensor isn't clearanced if need be or reluctor wheel not spinning true.
Lastly check sensor gap and get back to me.
#3349
We have done the easy part by building the best fabricated F-Body nine inch package on the market but now it is up to all of you to do yourself a favor and purchase it.
More options available than anywhere else and multiple ways to purchase. We still offer our layaway plan and offer it all year long. Click here to check out options and pricing.
Thank You Eric, Kevin, & Jason From Midwest Chassis Inc.
#3350
Kevin,
I talked to you a while ago about this, but never really got a definite answer on what to do and now that the car is running id like to figure it out. I'd like to add 3 channel abs to my 9". Wondering if you have any pics of it done and whether I need to send in parts or if I can just bolt it on. Thanks
Ryan
Ryan
#3351
Kevin,
Ryan
Ryan
You will just take your yoke off and use the new one.
The kit is $295 plus shipping.
#3352
LS1Tech Premium Sponsor
Kevin,
Ryan
Ryan
#3353
Thanks guys. Ill get ahold of you later this week. I will probably just send my yoke in. Do I have to look and see what center section I have? Do you stock the parts for it or what is the turnaround time?
Ryan
Ryan
#3355
It is crazy to think that this thread was started way back in 12-13-2007, 12:36 AM and has 3353 replies with 432,496 views. Most of those replies are from customers thanking us after their purchase. Some customers are on their second or even third rear end purchase for other vehicles. We attribute this to having one of the most efficient rear end packages on the market. We try to go above and beyond to make your purchase down to the install as simple as possible.
We have been pumping out fabricated nine inches for the F-Body platform for a very long time and had some great customer relations over the years. We appreciate everyone's business and if you ever have any questions please feel free to ask as we would be more than happy to help you even if it isn't rear end related.
In 2017 we will continue to offer our layaway program with zero time limit as to when you can pay your purchase off. This has helped hundreds of customer get the rear end they wanted instead of settling for less and we are happy to offer this program.
Thank You From Midwest Chassis.
#3358
Awesome stuff in here. I wish I had the time to read through it all! The goal with my car is to be able to do a little of everything. For instance it has the Strano springs with Koni adjustables so I'd like to be able to toss a big tire on it and crank out a couple passes and then swap wheels later on and hit the road course. Jack of all trades, master of none if you will
I think one of these with the weight savings and 3.70 gear ratio can get me closer to my pipe dream
#3359
I'm on the verge of pulling the trigger on getting a MWC rear for my T/A. I've only been wanting one for 5+ years now. Had the car at the exhaust shop a couple of weeks ago and was informed that it may be time that I start looking to fix or replace the 10-bolt as it has leaking seals in 3 places. Considering I've had it 15 years now and put over 225k miles on it, I'd say the 10-bolt has done its job.
Only thing I'm waiting on is trying to find some backing plates so that my car isn't down the entire time I'm waiting on the rear end to get here.
#3360
I'm on the verge of pulling the trigger on getting a MCC rear for my T/A. I've only been wanting one for 5+ years now. Had the car at the exhaust shop a couple of weeks ago and was informed that it may be time that I start looking to fix or replace the 10-bolt as it has leaking seals in 3 places. Considering I've had it 15 years now and put over 225k miles on it, I'd say the 10-bolt has done its job.
