gear whine and grinding
Old 02-29-2008, 11:10 AM
joker_01z28's Avatar
Default gear whine and grinding
Okay well as the title states it sounds like a gwhine and slight grinding sound when i deccelerate.im going to put in the limited slpi additive because when i had a shop change my gears i doubt the put that stuff in. i know when i changed gears it would probably whine but not like it is, thanks
Old 02-29-2008, 11:51 AM
Bonertee's Avatar
What gears did you go with? I went with Motive 4.10 in my 10 bolt and it makes some noise. Though it is getting worse the more I beat on it.
Old 02-29-2008, 12:52 PM
there richmond gears and went from 3.23 to 3.73
Old 03-01-2008, 03:18 AM
badazz99ta's Avatar
from what i have read and understand, richmonds are really loud/whinny. i have motive 4.10s and i have had motive 3.73s and they, to me, make little to no noise.
Old 03-01-2008, 06:14 PM
well my spider gears blew up, awsome.
Old 03-01-2008, 06:55 PM
TA1364's Avatar
I had the same problem after install, pinion nut came loose
