Attn: Rear end guys, input needed
Attn: Differential guys, input needed
I was on ebay earlier and came up upon this 9 inch housing. What is needed to complete the rear end and about how much would it cost to finish.
http://cgi.ebay.com/ebaymotors/ws/eB...id=p2759.l1259
Thanks
Thanks
"Rear end guys, Imput needed" one could easly misconstrue that but its funny. I didnt read the entire thing but it looks to just be the housing right? Void of the third member (gears) and both axles right? Is it for a 3 channel set up or 4? Things you may want to ask.
not sure about the 9" i was under the impression older housings such as this one only came as 4 channels and 3 channel options are fairly recent, but im not 100% sure, someone else with more ford 9" knowladge should chime in soon though, see this link https://ls1tech.com/forums/gears-axles/843206-moser-9-inch-3-channel-now-available.html
LS1Tech Sponsor
Looks like Currie housing, best bet would to purchase a new Moser housing. Better TA mount and the housing ends will accept your stock brakes. The housing ends that are on there are large Torino.
So what type of brakes would i have to use? Would i be able to get different ends put on to run the stock brakes or some kind of backing plate adapter? Thanks
