Need help identifying my 12 bolt please
I have a 12 bolt on my vehicle but am in need of identifying if it is a Strange or Moser so I can order some LCA relocation brackets.Any and all help is appreciated.Thank you for your time.
I am pretty sure the moser uses 4 bolts for the torque arm where as strange uses 2. If I am mistaken its cause I have been studying all night and need to go sleep
yeah found this on umi's site, so I am not tripping
Rear Torque Arm Hardware Kit- We highly recommend purchasing a new hardware kit if running this torque arm on a stock rear, Strange or other similar rear-ends that use a straight through bolt design. OEM torque arm bolts will work however are slightly too short and may not fit correctly. If you are running a Moser Engineering 12-Bolt rear-end this kit is not needed, you must reuse hardware supplied by Moser Engineering. New hardware kit will work on Moser Engineering 9" rear ends.
thats probably the easiest way to know, if its not a strange or moser I have no idea, how else to tell
might be a currie rear???
I had to stick on my moser decals myself. So its possible whoever put in the 12 bolt may have not put them on. just saying that they are not put on always and are not stamped on either
