Odd Rear End Noise
Odd Rear End Noise
so i searched the forums and couldn't find anyone with a problem like mine, so i figured a new thread was in order.
last week, i put a set of motive 4:10 gears in the stock 10 bolt, everything went in perfectly. pinion depth was right, backlash at .006 and they were as quiet as could be during the break in period.
i started to get into it a little bit yesterday, still no hard launches or shifts and barely any WOT.
Now, the odd thing is i get a loud noise when im turning right, but only if its coasting. if im on the gas through the turn they're quiet. no noise in reverse in either direction. a tiny bit of noise when just coasting to a stop while in gear, but nothing to bad.
any ideas what could be causing this ? im going to open the rear end up soon to double check the wear patterns, and i'll see if i can get some pictures up.
ok, so i jacked the car up and put in gear to let it just spin and theres a pretty nasty noise coming from the passenger side axle. Im thinking maybe the wheel bearing is bad. i haven't had a chance to pull the axle out to check it out because i have to work, but I've got the next 4 days off so ill be doing that.
maybe tomorrow after work I'll throw a video on here of the noise n such.
so i got around to pulling the cover off, and getting the carrier out to get a better look at the wear pattern and heres what i found. (the picture is from my phone. but you get the idea)
what do you think ?
oh, and i could clearly see the bearings on the right side when i took the clamp pieces off, and there was some side to side play with the carrier.
any ideas ?
what do you think ?
any ideas ?
