Stock 2 series ring bolt, got a ?
I have the stock 2 series carrier and I would like to change to 3.73s. Is there any problem with reusing the original ring gear bolts? I am not sure how long the bolts are, but I am going to a thick ring gear.Info is appreciated
You can reuse the bolts no problem. Be sure to clean them off with brake cleaner so there is NO oil on the threads and use red loctite on every bolt. BTW, they are LH Thread .
Jeff
Jeff
Thanks, I will be calling you very soon for a package.I also need to know if you sell the tools to set up the ring and pinion,ie marking compound and such.
