Info needed on DANA 44
Old Nov 4, 2007 | 10:28 PM
ZONES89RS's Avatar
In-Zane Moderator
Default Info needed on DANA 44
I bought this diff today, i need to know where to get a axle(one is slightly bent). I also need to know how hard it is so set the ring and pinion up, the guy i bought it from dug into it and did not know what he was doing. I bought it for 380$, what you guys think?
Old Nov 4, 2007 | 11:03 PM
Scott@DrivelineSolutions's Avatar
LS1Tech Sponsor
8.5" ring gear, 30 spline axles and there are more upgrades that you can do to help keep it together.
Old Nov 5, 2007 | 12:46 AM
ZONES89RS's Avatar
In-Zane Moderator
What brakes can i put on it? I need to know where i can get a axle for cheap, maybe somone to help me set the ring and pinion too.
Old Nov 5, 2007 | 02:34 AM
Revelation Z28's Avatar
dana 44 is 8.5" and mounts to our cars?? i didnt know that.
Old Nov 5, 2007 | 03:43 AM
ZONES89RS's Avatar
In-Zane Moderator
This is a verry rare rear from what i have found, it was available a while back but it was factory in the rare 92(i think) firehawk(i think) which was supposedly 375 hp. This is from what i hear, nothing more, but you can clearly see all the bracketry is stock for a 82+ setup.
Old Nov 5, 2007 | 01:07 PM
jimmyblue's Avatar
Moderator
Seems like a nice way to go, wonder if there's a way to get
the 4-channel ABS reluctors on there. Any idea how this
compares to a 12-bolt for weight? Seems like maybe a
driveline vendor could get a pallet of 'em out of Dana and
offer something cleaner than the current 12-bolt-conversions.
I know I'd rather go that way if the ABS/ASR can be fitted.
Old Nov 5, 2007 | 07:36 PM
LS1-IROC's Avatar
Nice find!!!! I have been trying to get my hands on one of those rears for some time now.
Old Nov 6, 2007 | 12:29 AM
OldeSkool's Avatar
man that'd be a dream come true..
even better if GM would work out an exchange program... send in your busted 10 bolt and get a free Dana 44
Old Nov 6, 2007 | 12:38 AM
LS1Tech Sponsor
SLP and Summit did offer these in a 3rd gen width, I even think Summit had a sale on these a few years ago. Dana did produce them and they are listed in Dana Spicer GXT books. You could cut the ends off and have a LT1-LS1 style housuing end installed and that would allow you to run a 4 chanel ABS system.
Scott @ DLS
Old Nov 6, 2007 | 02:09 AM
ZONES89RS's Avatar
In-Zane Moderator
****, it is a 3.31 not a 3.53. Guess i gotta find something off Ebay. I am happy to ditch the 7.5 soon!
Old Nov 6, 2007 | 02:57 PM
LS1Tech Sponsor
The F-car Dana 44's did have a crush sleeve but a standard Dana 44 gear set will work with the preload shims. I do have a few good used ones here for $85.00.
Scott @ DLS
Old Nov 6, 2007 | 11:56 PM
ZONES89RS's Avatar
In-Zane Moderator
Thanks man, ill let you know if i need anything, i have a guy with a axle and a 3.73 gear set he might sell me for cheap, then ill be set!
Old Nov 7, 2007 | 11:58 PM
ZONES89RS's Avatar
In-Zane Moderator
Scott @ DLS
Do you happen to know where i cna get a passenger side axle for cheap?
Old Nov 8, 2007 | 01:40 AM
LS1Tech Sponsor
Your gonna have to have one made cause they are obsolete.
Old Nov 8, 2007 | 04:18 AM
ZONES89RS's Avatar
In-Zane Moderator
By that i am guessing you mean that the size i need is third gen specific right?
Old Nov 8, 2007 | 11:37 AM
LS1Tech Sponsor
Correct, nothing will inner change.
Old Nov 8, 2007 | 11:56 AM
Torkman15's Avatar
10 Second Moderator
Thats a helluva score you found. The brake brackets look like they accept metric front calipers. No e brake though...someone makes what you need...SSBC?
Good luck to ya, Tom
Old Nov 9, 2007 | 03:21 AM
ZONES89RS's Avatar
In-Zane Moderator
I got a set of iron brakes on a 9 bolt that should bolt up, i wanna go with PBRs or even LT1 brakes, but that will be later down the line. I wonder what kind of 60' i would cut with a 3.31 gear?
Old Nov 10, 2007 | 02:44 AM
ZONES89RS's Avatar
In-Zane Moderator
Got any suggestions on where i can get one made???
Old Nov 10, 2007 | 11:06 AM
LS1Tech Sponsor
Moser, 260-726-6689
