Moser 12 bolt and Torque Arms
i currently use my stock TA, but am debating getting a used Moser 12 bolt due to the price and its already all assembled,,,
will my stock TA work with it?
what aftermarket (i know not edlebrock) TA will work?? (as i will update eventually)
Thanx All!!
Thanx All!!
im a stock ride height guy, and have no plans of changing this,,,would the BMR non-adj be well enough for my needs? (i will end up with under 500 rwhp when im finished with this street rod)
I would spend the extra for an adjustable torque arm. A non adjustable torque arm simply has no reason being on our cars. You simply need to be able to adjust the pinion angle. Bob
1 Post
I called BMR before starting my install, and they highly suggested to use the center bolts on the torque arm mount, which will involve cutting the edge of the mount (and losing the outer holes).
Hello,
All our torque arm set-ups will work just fine with a Moser 12-Bolt as well. They are supplied with (2) sets of mounting holes as well to allow the arm to be slide inward if needed. We have adjustable torque arms starting at $299.99 and a full list can be seen in the link below.
http://www.umiperformance.com/produc...ategory_id=130
If you have any questions please ask. Thank you!
Ryan
Ryan
