Eaton True trac?
Eaton True trac?
I have 12 bolt with the eaton true trac and 410 gears.Im currently running lucas 80/90 gear oil no limited slip additive.I'm do for change on the rear end fluid just want to find out what I should use car is a 6spd if that matters.
