Differential Cover Question
Old 07-07-2008, 07:48 AM
FLA02TA's Avatar
Default Differential Cover Question
I just installed a Thunder Racing (TA) diff cover this weekend and noticed it doesn't have the magnet inside like the stock had. The stock cover had some metal shavings on it which I expected after researching.
Does the TA cover have this built-in somewhere that I'm not aware of? It seems important =P
Old 07-07-2008, 09:19 AM
DRGnFLYZ28's Avatar
My JEG'S cover didn't either. Plus it's aluminum so it won't stick
I believe the intent of the drain and fill plugs is that you will maintain it more offen that OEM recommendation thus negating the need for the magnet.
Old 07-07-2008, 10:04 AM
FLA02TA's Avatar
Good to know. Thanks =)
Old 07-10-2008, 06:49 PM
mikenews's Avatar
Im almost wondering if u can put the magnet in the bottom of the diff.....
Old 07-10-2008, 07:22 PM
shoemike's Avatar
or you could use a magnetic drain plug.
Quick Reply: Differential Cover Question
