Pinion angle check please!
Old 08-01-2008, 03:52 PM
onebad82z's Avatar
Default Pinion angle check please!
If I have a transmission output shaft angle of -3 degrees ( pointing down ) and a differential pinion yoke angle of +1.5 degrees ( pointing up ), I than should have a pinion angle of -1.5 degrees correct? Pretty sure this is right, but I always get mixed up when setting these angles up. No driveshaft in right now as that just confuses the issue even more for me.
Old 08-01-2008, 04:11 PM
CW00BlackTA's Avatar
You got it!
Old 08-01-2008, 07:37 PM
onebad82z's Avatar
Originally Posted by CW00BlackTA
You got it!
Thank you!
