U-Joint straps and bolts
Old 09-05-2008, 05:52 PM
BADBOYZ28's Avatar
Default U-Joint straps and bolts
I need the part # or anywhere that I can get the correct U-joint straps and bolts for a Moser 12 bolt. I already got the conversion U-joint from stock DS to a 1350 yolk. Now I just need those damn bolts!! Help please........
Old 09-06-2008, 11:30 AM
BADBOYZ28's Avatar
Anyone??? HELP.....
Old 09-06-2008, 11:59 AM
EPP
EPP's Avatar
http://www.exoticperformanceplus.com...html?item=1530
Here are some made by Moroso. Bob
Old 09-06-2008, 01:34 PM
BADBOYZ28's Avatar
Those will work with a Moser 12 bolt correct? Cause it says Dana60/Ford 9"! What about the Moroso 85830 or Moroso 85810?
Old 09-06-2008, 02:02 PM
LS1Tech Sponsor
Scott@DrivelineSolutions's Avatar
Spicer part number 3-94-18X
Old 09-06-2008, 02:17 PM
BADBOYZ28's Avatar
Who carries that part? Also is that the straps or the bolts? Both?
Old 09-06-2008, 02:56 PM
LS1Tech Premium Sponsor
ssvert99's Avatar
o'reilly auto parts usually has them... Precision u-joint # 330-10... same as the Spicer # above. it is a u-bolt kit, comes with everything you need.
Old 09-07-2008, 10:16 PM
BADBOYZ28's Avatar
Thanks guys for your help. I got the parts at o'reilly auto parts so I finally finish this damn swap! Once again thanks for your help....
Old 09-07-2008, 10:34 PM
Bird's Avatar
What coversion u-joint did you use - PN ?
Getting ready to do this same swap myself.
Bird
Old 09-08-2008, 11:32 PM
BADBOYZ28's Avatar
Bird
You can get it at Napa its P447 I think. Whatever you do don't cross refrence the same part # to Orielys or Autozone its still a u joint just the wrong on. I found that out the hard way get it at Napa.
Quick Reply: U-Joint straps and bolts
