Old 05-06-2016, 01:05 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Chevrolet Camaro or Pontiac Firebird Engine Guides
Print Wikipost
Best Air Filter
Old 12-26-2009, 01:13 AM
camaro 626's Avatar
Default Best Air Filter
Hi
so what's the best air filter for the ls3 ??
plz search thread are not acceptable
Old 12-26-2009, 02:42 AM
sway99bird's Avatar
NO AIR FILTER !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
JK the stock one will be fine just save for a aftermarket intake IMO
Old 12-26-2009, 11:28 AM
blk/slvr02ss's Avatar
RotoFab makes the best cold air system but just for a stock replacement i would go w/ K&N.
Old 12-26-2009, 04:42 PM
Evo8You's Avatar
Originally Posted by blk/slvr02ss
RotoFab makes the best cold air system.
That is completely incorrect.
Rotafab made the LEAST avg HP out of all the top intakes.
Fastlane and CAI had the most HP, but fastlane's needed a tune to avoid knock.
Otherwise go with a K&N panel...
Old 12-26-2009, 10:35 PM
ex-SS-ve's Avatar
Fastlane and CAI had the most HP, but fastlane's needed a tune to avoid knock. Otherwise go with a K&N panel...
ide like to see how these tests were performed and whether the car was already hot or they just ran cold tests. i had mine dynoed after the car was driven about 30 miles hot off the street in 98+degree weather with a rotofab cai on my otherwise stock 2010 m6 ss and it made 390 rwhp. this was done at about 3000 miles
Old 12-27-2009, 01:29 AM
ecmoman's Avatar
All the tests for each CAI were done exactly the same. Car was run with new CAI installed to get the PCM to "learn" the new system, then the car was brought up to operating temp before being dyno'd. All test were done with the hood down and fans blowing on the front of the car to simulate driving. The test car was bone stock, right down to the factory intake.
Old 12-27-2009, 03:27 AM
hitmanws6's Avatar
OP keep your stock air filter, on a stock intake the horsepower gain from a different filter is very minimal. And as far as CAIs for the 2010s go, shouldnt they all be roughly the same? there isnt any way you can make them different from each other, you are paying for a brand, fitment and the look. its just an open filter into an elbow
Old 12-27-2009, 04:11 AM
ecmoman's Avatar
That's not entirely true.
A K&N filter was shown to gain absolutely nothing in terms of power. I'm sure it would do a better job at filtering though.
CAI's can vary quite a bit from manufacturer to manufacturer. Size, placement, filter used, and heat shield fitment plays a huge roll in getting the absolute coldest air into the intake. Radiusing the tube intake can make a fairly noticeable difference as well. Take Hennesey's intake for example. It's a $500 POS that has no heatshield at all and was the worst CAI they tested. It barely showed any improvement over the stock box and in some instances it was worse. Take the same design and add a good fitting heatshield to it and it will gain 5-10whp more. It's not just about getting a big *** tube with a filter on the end of it. There is a little science and experimentation to it.
Quick Reply: Best Air Filter
