Old 05-13-2016, 12:10 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Chevrolet Camaro or Pontiac Firebird Tire Repair and Maintenance
Print Wikipost
What Size Drag Wheels & Tires for the 2010?
Old 01-25-2010, 01:45 AM
SJMMFGINC's Avatar
When we built and installed our new Bogart wheels on the car pictured above, it was designed to be a direct fit for the 2010 Camaro using brembo large brakes.
The wheels are custom built. They aren't going to be 500.00 per set but you get what you pay for. We are the only folks building 17's to be a direct fit on the new Camaro.
Though the wheels aren't inexpensive and not for everyone due to costs, you WILL save quite a bit on tires as they are much less expensive vs. any other alternatives.
Attached is a real nice closup of that car when we were installing them to verify fitment.
If anyone has any other questions regarding our designs, feel free to let me know.
Attached Thumbnails What Size Drag Wheels & Tires for the 2010?-sjm-manufacturing-inc.jpg
Old 01-25-2010, 11:01 AM
m6z
m6z's Avatar
Originally Posted by OrangeChevyII
I don't, none of us do.
any picts of your set up?
Old 02-02-2010, 11:07 AM
99FRC's Avatar
Any reason you couldn't use these daily?
Old 02-02-2010, 09:24 PM
OrangeChevyII's Avatar
No pics, just a heads/cam car with a custom cai and a plate.
Old 02-04-2010, 05:19 PM
99FRC's Avatar
Big wheel haters of America unite! This is how the wheels on a 2010 Camaro should look. If this one was dropped a bit, it would be perfect.
Old 02-23-2010, 11:57 AM
TRC
TRC's Avatar
Dark SS what tire combo are you running with those wheels, and are you happy with them. I just bought a set and have been trying to decide on the tires.
Old 02-23-2010, 01:45 PM
bad2000z's Avatar
I wonder if Bogart will make an 18" rear drag wheel. There seems to be more of a selection of 28" drag radials for an 18" wheel than there is for a 17".
Old 02-23-2010, 02:43 PM
bad2000z's Avatar
Well I just discovered M and H makes a 275/50/17 drag radial that's 28" tall. They also make a 325/45/17 but I'm not sure if they will fit. They are also 28" tall, but they are 12.6" wide.
Old 02-23-2010, 07:36 PM
g-townmach's Avatar
Those Bogarts are soooooooooo the way to go! No spacers needed?
Old 02-23-2010, 08:33 PM
SJMMFGINC's Avatar
We have no plans to create an 18" wheel. 17's will give better results being a lighter, smaller diameter wheel which creates a better resultant for sidewall height. The typical tire used on the 2010 using our wheels is similar to a person using 28's on a 15" wheel using the old LS1 F-body configuration.
M&H has a very good selection of tires. John from M&H has also relayed to us that 28" front runners are in the works as well. This is great news as it will fill up the front fender well very nice.
A 325 is a pretty wide large tire. I can't validate whether it will fit or not. None of our customers to my knowlege have attempted that size. We may need to move the wheel inward slightly...we can do this but keep in mind the outer dishing will be smaller then.
you could be one of the first or you may want to wait until someone else tries it...most are using 295's as we know those work perfectly fine.
G-townmach No spacers or mods are needed. You bolt and go. It re-uses the stock lugnuts. We place tapered seats in the wheels for ease of using the stock lugnuts. We could offer shank style, but they are not so readily available to end users.
Old 02-23-2010, 08:58 PM
ethang1977's Avatar
I agree. The 17" wheels look perfect!
Old 02-23-2010, 10:36 PM
  #32
Dark SS's Avatar
I don't have those yet for my car, I just found the pics. Hopefully by next year.
Old 02-24-2010, 07:06 AM
  #33
TRC
TRC's Avatar
Does anyone know whose car that is in the pictures. I would like to know what tire combo he's running.
Any thoughts OrangechevyII, Would you recommend going right to the slicks or go with the drag radials?
Old 02-26-2010, 05:22 PM
  #34
SJMMFGINC's Avatar
That was the first local car that got our very first set of our custom 2010 wheels. Those tires are 295/50 on the rear. The fronts are M&H's skinnies. Shortly, there will be larger diameter front skinny M&H tires available as an option.
I've got a few other shots of it as well. I have a bunch of shots of the car when we installed the wheels...it doesn't have the tires on the car though.
Regarding other tire choices, since everything is so new and we don't have the history yet, I can' t recommend one tire over another. Typically, ET's will be lighter giving better consistency among other benefits.
Old 02-26-2010, 05:27 PM
  #35
SJMMFGINC's Avatar
Same reason why any other drag wheel on the market is not intended for daily usage. These are actually setup very robust...though you'd probably not have any issues with them, I can't tell you to use them as such due to liability.
Daily driving to me means 15k+ miles per year...its your primary vehicle and you do everything with it.
I'd probably also suggest for daily usage to go with larger front wheels. Skinnies aren't the best for turns for obvious reason. I'd suggest our road race wheels if you want the most durable setup that will take just about any type of abuse.
Old 02-27-2010, 08:35 PM
  #36
mongoose z28's Avatar
Originally Posted by jamnut
I love & want the Bogarts, but I'm stuck with 18" C6 wheels with 315-35-18's on them. Once I get my 3.73's & have the shorter wheel, she should 60 really well. The wheels they are compared to are 305-35-20 Nitto 555r's, the 18's are Toyo Dr's, really like them so far. Sorry for the quality, Iphone pix.
I will end up with the bogarts one day soon.
Can you tell me the full specs on your c6 wheels that you are using? I need this cheap option for the track too. just a thought but have you ever tried those on the front? Are you using the C6 offset or c5 offset? Did you need spacers? I would assume the width is 10.5"?
Old 03-11-2010, 12:59 PM
  #37
bluehawk2's Avatar
We ordered Bogarts for a 2010 camaro. We used the M&H 325/45/17's and they fit perfectly.................I have the 275/50/17's on my car with 9.5" wheels and they run a little narrow even on those wheels, so the 325's are a perfect tire for the bogarts
We had the M&H front runners , but it really look bad being a short tire...........we took those off and are now running some michelin tires that are 27" tall. They are deff a heavier tire, but they look and ride a lot better.
Old 03-12-2010, 01:15 AM
  #38
Jeramey@StrictlyPro's Avatar
Any information on what size the M&H's were ordered for the front? Trying to find them so I can order them.
What were the specifics on the Michelins?
Old 03-12-2010, 07:05 AM
  #39
Race your car!
JL ws-6's Avatar
There is one nice thing, the wheel cutout judging by the looks will probably fit a 29 inch tall tire, probably a 30 inch, which is nice, now someone just has to come up with a 30 inch bias ply tire that will fit on a 17 inch rim so they'll work decent, or someone can find a way to put a small brake caliper on the back so you can run a 15 inch rim again, they'd sell like mad.
Actually, a nice solid axle conversion would be even better, then ya could just throw anything on there for a brake. That would be best.
Old 03-17-2010, 08:32 PM
  #40
bluehawk2's Avatar
I'll try and get the exact tire we used..............send me a pm and remind me! I'm really busy and I forget easily..lol
I know the tire was really for a 6" wide wheel, but they don't bulge out or anything...no safety issue.
Quick Reply: What Size Drag Wheels & Tires for the 2010?
