Gen 5 Racing Tech Heads, cam, valvetrain, short block discussion
Livernois KB 3.6 LC Stroker 2010 Camaro Build
Old 07-27-2010, 06:27 PM
LivernoisMotorsports's Avatar
Default Livernois KB 3.6 LC Stroker 2010 Camaro Build
Earlier this year, we built an L99 Camaro for a customer that consisted of a Livernois 419 stroker longblock, built A6, and Magnacharger 2300 S/C.
As far as we know it's the quickest 2010 Camaro on 20's and the quickest Magnacharged 2010 Camaro.
The car weighed 4,130 with me in it and went a best of 10.44 @ 135 mph on widened factory 20's and Nitto DR's.
The customer wanted more, so we are currently installing a Kenne Bell 3.6L liquid cooled S/C with our custom 10-rib kit and Alky Controls methanol kit. I can't wait to see what kind of numbers it puts down. It would be impressive to go 9's on 20's
Alky Controls Pump
Livernois Motorsports wiring for the meth kit
10.44 Video
Video
Regards,
Rick LeBlanc
Old 07-28-2010, 11:38 AM
icen's Avatar
how are yall controlling the iats? I have a 2.6kb c6 and with 11psi only put down a lil over 530 down.
Old 07-28-2010, 05:34 PM
97power's Avatar
Awesome resluts. What kind of lbs of boost and compression does the car have and what kind of boost will you run on the KB setup to see the differences.
Old 07-29-2010, 11:16 AM
The LC KB should help with the IAT's.
Thank you! It's 10.4:1 and we plan on running 18-20 lbs.
The Maggie made around 15-16 lbs.
-Rick
Old 07-29-2010, 04:14 PM
GPG 02's Avatar
That’s a sick build…Good luck with everything, I look forward to seeing the results.
Old 07-29-2010, 09:13 PM
I'm looking forward to the results too... from this one and a slightly crazier one which is also in process and can be seen here
- Rick
Old 08-20-2010, 03:21 AM
Luckymex_dallas's Avatar
Hurry!
Quick Reply: Livernois KB 3.6 LC Stroker 2010 Camaro Build
