Gen 5 Racing Tech Heads, cam, valvetrain, short block discussion
MS3 in a L99??
Old 01-08-2015, 10:47 PM
1320BIRD's Avatar
Default MS3 in a L99??
with the exception of replacing lifters , could you run an Early LS style cam such as a MS3 cam in a later L99 pro's and con's
GO !!!
Old 01-09-2015, 11:38 AM
BODUKE's Avatar
What heads?
Old 01-10-2015, 05:43 PM
62nalide's Avatar
I would not, get you a nice VVT cam for low end AND top end
Old 02-10-2015, 10:51 PM
subeone's Avatar
seen one in a ls3 4 door 07 silverado with a 4l60e and a bullshit 3600 dacco converter snap a 1.5 60', and hit a 12.3x at 109 mph all motor. The intake valves did hit the pistons a tiny amount but then again the heads were milled .020".
just if you were curious what that cam does in a ls3
Old 02-26-2015, 12:40 PM
rgvbandit's Avatar
it should work
Old 03-03-2015, 01:02 AM
onebadbowtie86's Avatar
I'm looking at doing ls3 heads on my ls2 with the MS3 cam. So the valves should clear the heads in stock form, but milling .020" to keep the CR up could cause PTV issues?
Old 05-06-2015, 10:21 PM
1320BIRD's Avatar
what do you suggest ? need best bang for buck most hp
Old 05-07-2015, 01:35 AM
62nalide's Avatar
Are you wanting to do a converter also? I would look at GPI (gweatny performace innovations) they are real good on VVT cams and also TSP.
Quick Reply: MS3 in a L99??
