General LSX Automobile Discussion Non-technical LSX related topics.
Proper jack stand placement..
Old 12-05-2011, 04:55 PM
JustAFooL's Avatar
Default Proper jack stand placement..
Does anyone have pictures of where to properly place the jack stands?? I feel safe with my front end, but I'm worried about the rear. Having a hard time getting the floor jack in a proper place and considering the trans is blew, its probably going to be up in the air for a while..
Old 12-05-2011, 06:55 PM
Starz T/A 17's Avatar
When I jack the rear up I generally put the jack stands under the differential or some part of the frame. And then I keep the jack under the center of the differential as added safety
Old 12-05-2011, 07:05 PM
71novaguy's Avatar
just be careful when jacking the center of the diff. you can bend the cover pretty easy.
Old 12-05-2011, 07:22 PM
dwfronk's Avatar
When you jack up the rear of the car slide the floor jack under the car from the rear and jack up on the diff where the torque arm mounts to it. It will save you from tearing up the diff cover. I have always put the jack stands just in front of the control arms.
Old 12-06-2011, 01:48 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
http://www.installuniversity.com/ins...sity/index.htm
go to Install Documents, scroll down to miscellaneous, then click on LS1 lift points
Old 12-06-2011, 06:38 AM
blk/slvr02ss's Avatar
I Always put them under the frame right near were the lower control arm bolts !
Quick Reply: Proper jack stand placement..
