Cooling Fan Always On - Any Suggestions
Over the last couple days both cooling fans come on as soon as car starts. They don't run with engine off and I checked relays - appear to be functioning OK. This is a cold start after sitting overnight. (99 Z28 - all stock)
After looking at wiring diagrams and some searching, I came to the conclusion it is either a bad ground or PCM is turning them on.
I started car and disconnected the A/C pressure switch. When I plugged it back in fans stopped. My guess is a bad A/C pressure switch but I'm looking for any other ideas before dropping $50 on a pressure switch that I won't be able to take back.
thoughts??
thoughts??
The guage reads same as always - cold when starting in morning, warm up and sits just under mid point when driving. If fans start tomorrow AM I'll pull this and see if anything different happens.
