some questions
some questions
ok so ive found a camaro 2000 z28 auto black t-top.
im going to look it over an give it the once over tomorrow.
if i like it and nothing appears to be wrong with it ill take it home.
so does it really make a difference in 86 or 90 octane.
in the gas i use or what is there any real performance notice?
It can be done but it is very likely that you will see both less performance and MPG's with an octane lower than 91, I would suggest that you just run the premium fuel
LS1Tech Premium Sponsor
A lid is definitely a good choice, easy to install and has excellent gains for a cheap mod. Here is a link to them on our site:
http://www.texas-speed.com/p-267-slp-air-box-lid.aspx
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
Don't be cheap with fuel. 90 octane should be fine.
Look at this link. It applies to your Z28 just as much as the T/A. https://ls1tech.com/forums/pontiac-f...s-see-pic.html
